All my motion seems correct sending GCodes to the Kmotion.net interpreter but it doesn't appear to be honoring the backlash settings.
I believe I'm setting everything properly programmatically at startup as all the other parameters are taking effect....but enabling/disabling backlash seems to have no effect. Here is a slice of the code I am using to set backlash settings:
Controller.GetAxis(X_Axis_ID,"").TuningParams.BacklashMode = BacklashMode_Enum.BACKLASH_LINEAR 'This is an integer 1
Controller.GetAxis(X_Axis_ID,"").TuningParams.BacklashAmount=.0032
Controller.GetAxis(X_Axis_ID,"").TuningParams.BacklashRate =0
Does backlash need to be enabled anywhere else to operate?
sam marrocco | chief technical officer
ringside.cutters.picnic.moonlink
248 548 2500 w
248 910 3344 c
ringsidecreative.com
